My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
좋은 질문 입니까?
lenovo a7000
좋은 질문 입니까?
I faccing same problem
help to out me from this problem
해당 답변은 도움이 되었습니까?
Facing same problem.
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
해당 답변은 도움이 되었습니까?
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
해당 답변은 도움이 되었습니까?
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
해당 답변은 도움이 되었습니까?
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 14,389
댓글 3개
lenovo a7000 switch solution
ali 의
my phone was not getting charged more than 15% and now it cant be switched on? plz help
ankitaprasad3026 의
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
arun s patil 의
