주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
Hard Drive Upgrade Limit
What is the Hard Drive Size Upgrade limit for a
Apple Mac Mini 1.66GHz Intel Core Duo Computer, Model MA607LLA
original configuration -
1.66GHz Intel Core Duo processor
2MB L2 Cache
667MHz Frontside Bus
512MB of 667MHz DDR2 SDRAM (PC2-5300) on two DIMMs; supports up to 2GB
60GB 5400-rpm Serial ATA hard disk drive; optional 80GB, 120GB or 160GB drive2
Combo drive (DVD-ROM/CD-RW)
Built-in AirPort Extreme and Bluetooth 2.0
Apple Remote
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
I have changed from 80GB to 500GB and it works just fine.
댓글 달기
답변 3개
선택된 답변
Your machine uses a Serial ATA standard 2.5" hard drive. The largest drive I found that would work for you is 640 GB: [연계 제품이 누락 또는 비활성화 됨: IF107-086]
Here's an excellent tutorial on how to replace it: http://soledadpenades.com/2007/11/01/diy...
I just discovered this and thought it might be of interest: CPU can be replaced with a faster "Socket M"/"Socket M" Core Duo or Core 2 Duo
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Very nice guide. + Ralph
댓글 달기
Now that 1TB HDs with 9mm height are available, you can also upgrade the internal HD to 1 Terabyte. I just finished it and it works fine :)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The Western Digital Scorpio Blue (WD10TPVT) 1TB fits. Its has a12.5 mm height and I have one installed in the upper bay. Its snug but works fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
David Bell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 9,138
