Why isn't my bike shifting?
When I shift through my gears it won't switch to every gear. Sometimes it skips a gear or won't shift at all.
좋은 질문 입니까?
좋은 질문 입니까?
Your shifting troubles is likely caused by your derailleurs. Dmadro's explanation is correct, but if you are unsure how to make these adjustments, you can take a look at one of the guides explaining each step on adjusting the front derailleur and rear derailleur.
안내서
난이도:
아주 쉬움
10 - 20 minutes
안내서
난이도:
쉬움
10 - 20 minutes
해당 답변은 도움이 되었습니까?
Check the shifter cable. There is an adjustment at the rear derailleur that you can turn to loosen or tighten the cable tension. Put the chain on the smallest gear on the rear wheel. Shift up to the next gear. If the shift does not happen, turn the cable adjuster to tighten the tension on the cable. If you shift and the chain moves up two gears, loosen the cable. Park Tools is a good website for this sort of adjustment.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 10
30일 전: 24
전체 시간: 7,216
