주요 콘텐츠로 건너뛰기
Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
I broke my tablet by dropping it. Can someone help me?
I was at a track meet playing on my tablet but then I dropped it on hard soil. Should I get a new one, or can you help me fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 7개:
Jj Fish, what does your tablet do, or not do? what have you tried?
Well, mom told me to plug it in. Then i tried to power it on, so it showed gray for a few seconds, then it would dim for a second. then it would be gray again for a minute. then the screen would turn off. then i tried holding the power and +V. it would be gray with lines and boxes forever. then i decided to hold the power button. i tried this a lot of times and it did not work.
It would help if you had a better picture and what kind of tablet it is. Most likely it's fixable but it will take some disassembly.
My step-daughter dropped mine and it hasn't turned on, or taken a charge since. Can I send it in for repair's or do I just need to trash it?
My screen is broken ,, can it be replaced?
댓글 2개 더보기
댓글 달기
답변 4개
can i email you the photos?
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Is the screen broken or it just won't turn on or both?
My screen isn't broken, it just won't turn on!
image|642 [124] This is my black screen tablet!
댓글 달기
Tablet doesn't have a Crack just lines come on the screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
When I dropped it I had a kid fix it and they said a wire came loose when I dropped it. Then when they fixed it my volume button fell off and I pushed it back in and only the volume up part worked. The other side feeled like nothing was under it and the only thing supporting it was the other side. And then afterwards it just took a dumped on me and it has been lying on my living room floor since for like three months now.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
and then it showed nothing but it was acting like only that the screen wouldn't turn on because after I charge it for a while and prees the button like I would if it died, whenever I touched it, it would make a noise
댓글 달기
I actually dropped my visual land how can I get it fixed and how much
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It got dropped by mistake how can I get it fixed
댓글 달기
답변을 추가하세요
Jj Fish 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 890
