The lever dose not move feed dogs up and down
please help
좋은 질문 입니까?
If the machine has not been used in a long time, the lever and/or feed dog mechanism might be frozen. It will take patience and time to oil with something like Tri Flow (might need to set for a while to penetrate), then use the warm setting on a hair dryer at low speed to heat up the area as you move the lever up and down. The closer you can get to the problem area the better. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 845
I also have same problem
franp 의
