주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
탑승형 잔디 깎는 기계. 제로 턴 반경 잔디 깎는 기계, 50인치 커팅 데크, 유압식 자동변속기.
My craftsman zts 7500 mower cranks over, but will not start?
What is the matter?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
It could be many things. First I would check to see if it is getting fuel, then check the spark plug for carbon and gap then the charge going to the spark plug.
이 답변이 도움이 되었나요?
점수 8
댓글 3개:
mine did the same thing and i changed the plugs and it started right up. from stretch.
의
My lawn mower my lawn mower is is the same thing as a 75 00 at 26 horsepower at Craftsman when you take the the wire going from the both cause then I guess I guess part between of course if I put the wire back on it no spark
의
It's got to be in a safety switch that will fix your problem
의
댓글 달기
There is a fuel lock (electrical cylinoid) at the bottom of the carburator that could be stuck. I had this problema and fixed it by taking it off and cleaning it. Started right up afterwards.
이 답변이 도움이 되었나요?
점수 5
댓글 달기
On mine both sparkplug lost compression. That means a total loss of the engine .and it wood run about 8 too 1 thousand too fix it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
James 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 35
전체 시간: 5,896
