주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
740 질문 전체 보기
Why does it keep on restarting?
When I shut down my system, it keeps on restarting.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 6개
선택된 답변
Could be a permissions issue.
Insert your OSX install dvd and hold option on startup or when it restarts.
You will have the option to boot from HDD or DVD choose DVD.
Once it loads (may take a few minutes) select disk utility.
*You may have to select a language or something.
In disk utility select you HDD and then you can "check disk permissions" and "repair disk permissions".
This may be the reason it keeps restarting when you shut it down.
It also could be a pending install of an update that is corrupt, but this should correct that issue.
If not let us know.
Good Luck!
-Varsity
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Would a Mac OS permissions issue make it happen in Windows also?
If its running windows through boot camp yes its possible, but windows itself is a whole other issue lol.
댓글 달기
가장 유용한 답변
Have you tried to shut it fully down by holding the power button down till it goes off (forced shut off?)
That should keep it off - and maybe it behaves after you start it up afterwards - give it a shot
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
that would be my first try!
Yes, only like that it would be turned off, but it doesn't matter in windows or mac os, when I choose shut down, it restarts itself, it is the First time that I'm facing such a problem.
댓글 달기
Try typing in the command-line:
sudo shutdown -h now
Sounds like a permissions problem though.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Could it be a battery issue?
May be a battery calibration will help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I've just started having this problem on my MacBook. Did you ever figure out what was causing your problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I would try resetting the SMC. Heres a TN on how to do it: http://support.apple.com/kb/HT3964
댓글 달기
ive been having the same problem with my MBP. I recently did some troubleshooting by replacing the hard drive with one from a full functional MBP. Even with the new hard drive, my macbook would still restart everytime. Thus proving that the issue is not software related. I'm stumped.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MEYSSAM 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 6,208
