주요 콘텐츠로 건너뛰기
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 질문 전체 보기
No service (out of service) after touch screen replaced successfully
Hi,
I have replaced successfully the touch screen as per the instruction given. Now mobile is working perfectly but unfortunately there is no signal. so not able to make calls and changed SIM cards for my satisfaction. I have done flashing with latest ROM available in MIUI website, but nothing works.
Please help me to fix the problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 5개
선택된 해법
Check the antenna contacts. if you can update snapshots of status, i would happy to help you
해당 답변은 도움이 되었습니까?
점수 2
9 댓글:
Hi,
Thanks a lot for immediate response.
Actually the antenna cable terminal came out from wire at Mother board end, but some how I connected.
That could be the problem for this right?
I have screen shot but not able to paste it here.
use low impedance cable and they shroud be short as possible only if you connect antennas manually because it is stable high frequency connectivity such as 1800 Mhz 2100Mhz. Cheers!
Thanks a lot.
how do i solve this issue ..please help ..recently replaced my screen and now it shows no service.!..PLEASE HELPP!!!
Please help me to solve this issue. i got screen replaced for my xiaomi mi4i. Network reception has become very poor
4에 댓글 더 나타내기
댓글 달기
Hi
Please hlep to check if these have one GSM Signal antenna has been assemble well.
Thanks
Jack.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
With Xiaomi Mi4 also not work after replacing lcd and touch screen :(
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
my mi4 display replaced but it shows mi logo after screen goes black help me plzzz
@husna Did u solved it? Try flash to stock rom, if it doesnt fix then maybe ur eMmc prob.
댓글 달기
Hi,
i also got my screen replaced for my Mi4i. network connectivity is very poor now.
Please help me to correct it. i dont know which part is the antenna.
Rishab
해당 답변은 도움이 되었습니까?
점수 0
3 댓글:
Hii, good evening everyone, my Xiaomi redmi note 3, just fell faced down and shattered. I am in Lagos, please where can I repair it and is it advisable to repair. So I do not end up with more problems, can I just put screen protector to cover the shattered face since it still works(the touchscreen). Thanks.
1500 screen buy from ebay and replace
Did u fix this? Recently i also replace my broken lcd screen. Same issues as u guys, no network after replacement. Now i regret i replaced the screen by myself.LCD works fine, but i dnt what goes wrong with no service and sometimes super pooor network.
댓글 달기
My Mi 4i screen is broken and part of the touch is not working..also the network drops many times and coverage is very less... Is this because of the cracked screen? Please help!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kannasen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 11,333
