주요 콘텐츠로 건너뛰기
Screen cracked, and now black spots appearing
The device has a thin crack, no problems with how it works. After it was left in hot car, a black dot appeared on screen, and now it is growing in size, obscuring an app icon.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 51
댓글 1개
thanks for your help...sounds like it may be more prudent to get a new one!
댓글 달기
답변 5개
선택된 해법
sounds like the lcd has a crack, the term "screen" is problematic, some say screen to the front panel assembly (aka the touch screen) and others call the lcd a screen.
but since the "touch screen" can't get a real black dot - it must be a crack in the lcd.
you have to replace LCD and if there is also a crack on the front panel - you must replace it too.
이 답변이 도움이 되었나요?
점수 8
댓글 2개:
i left mine in my pocket and pulled it out and it became like this
댓글 달기
its either oil from your hands getting onto the lcd screen or pressure points on it, I'm not sure which most people seem to think it's pressure points base on my solutions that have worked I think it's oil. First thing to do is cover it with something to stop it from growing(packaging tape worked at least as well as a screen protector on my droid x). After that, it will very slowly decrease in size by itself. If you get it cold it will speed the process along.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I've crack my phone like 3 times and now there a line of black things just growing into it, how do I fix that, also my phone is a j3 Luna samsung
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I have the same thing on my IPhone5c it have black spots on it and it want let me do nothing i tried to do everything and I went to put some water on it still did work so maybe try clicking home button 3 times or Try clicking the Home button 3 times (really fast). If that doesn't fix it, go to Settings/General/Accessibility/Triple-click Home, and select the "White on Black" option. Then, triple-click the Home button.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone has a crack and now a big black spot is on my phone how do I get rid of it or do I have to take it in for someone to repair it my phone is a LG k7
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Same deal here, I dropped my phone and running through the cracks it has this black liquid looking stuff, slowly growing if theres pressure in the area. What is happening here?
It is most likely that your LCD screen has been damaged. As you were running, The phone could have hit the hard surface and revealed the black ink spot below your screen. You can get the LCD screen replaced or get the whole thing replaced.
댓글 달기
답변을 추가하세요
lorettalevy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 76
전체 시간: 116,864
