주요 콘텐츠로 건너뛰기
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
162 질문 전체 보기
Why is my alienware M17X display flickering
Hello,
I have a M17X laptop from late 2013. My display is flickering when moved in different orientations. Initially i thought it was a screen issue so i disconnected the power and display connection to the screen. After cleaning and reseating the issue still occurred. Could it be a loose or defective cable in the screen or could it be a issue with the video card?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Yes . you are correct, fault con be coming from Video card, LCD cable and LCD as well
Trace it,
  • Check the graphic configuration set it to default level and see whats going on if same fault observed,
  • Connect you M17X to external Display and check any sign of flickering
if yes - fault coming from your Graphic chip
if no - you can determined LCD or Display cable make the trouble and both of coming together and you can the Display with cable
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Buddhika,
Thank you for the confirmation. I had re assembled the LCD and remounted it to confirm the fix was not GPU related.
Thank you,
Phil
댓글 달기
귀하의 답변을 추가하세요
psortino2007 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 12
전체 시간: 6,970
