주요 콘텐츠로 건너뛰기
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
87 질문 전체 보기
질문 마감됨
Took Carburetor apart...now wont prime.
My Echo SRM 261-t string trimmer was four stroking and would not go into high rpms as a 2 stroke should so I took the carb off to make sure everything was clean. It all looked good (I cleaned everything anyways) so I put it back together and now the primer bulb does not work. I took it apart again to double check I got everything back right and i can not find an issue. It is as if the air can't escape from the bulb so it can suck up the gas. It feels like you are just pressing on an air bubble but the air cant go anywhere. what did I do? Thanks, DJ
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I don't know what happened but after posting this I went back to the shop and it was working normally. Back in business for my face off with a scythe tomorrow!!!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 647
