주요 콘텐츠로 건너뛰기
Ethernet is a widely used computer networking technology that allows devices to communicate with each other over a network. It is commonly associated with twisted pair cabling, which is a type of cable that consists of pairs of insulated wires twisted together to reduce interference.
How can I check my rj45 cable what problem it is?
my rj45 cable is wrong, how can i check what problem it is?
Update
which brand cable tester is better?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
선택된 해법
Most brands accomplish the goal some are more functional than others but if you just want to test the cable to see if its OK a multimeter and a couple of pins or needles will do, tape the pins to the end of your multimeter leads set the meter to ohms and make sure you have continuity then carefully touch the ends looking for matching colors. If there's continuity in all 8 wires your good to go. Its a bit slow but if you have a multimeter then why buy a cable tester for just one cable Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
you mean multimeter is better than tester right?
a tester is just doing a continuity test all at once were the multimeter your testing one lead at a time.Same job just done slower
The answer by Buddhika Mahesh is better because it is more complete and because a hand-wired cable may contain other errors than continuity, primarily wrong wires to wrong pins. There are also two standards for how to configure these cables, T568A and T568B, both valid, but different. He mentions them and links to Wikipedia page with detailed data. He also mentions whether they should be wired as crossover or patch cables. The user may have a perfectly good cable, but may be using it for crossover, when it's configured for patch, or vice versa. Either misuse could cause problems.
댓글 달기
Hello kalvin,
  • Check whether having any damages of cable
  • There is two types of cable configuration
1. Crossover : use for Router,console DCE interconnect
2. Patch : use for peer to peer connection
Here you can find pin identification and cable type identification
You can find any cable broken or loss connectivity using multi meter or cable tester
RJ45 having 4 ground cables (White mixed) even if one of them broken still you have can communicate but full speed will not offer by Ethernet
also data transfer speed also depend on CAT cable type
More info
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
This is actually a much better, more complete answer than the "Accepted" answer. See my comments there.
댓글 달기
Look in the jack where you are plugging it in the wall or device. Check the 1st and last pins (1 and 8) to see whether or not they are bent more than the other pins. This would cause transfer issues.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
There are two things you can do:
1)Buy or borrow a new Ethernet cable; plug it in, see if the problem goes away.
2)Buy or borrow a cheap Lan Cable Tester; It checks for continuity in all eight pins simultaneously, determining whether the cable, or, one of the connected devices are at fault. If you are lucky the Lan tester will identify crossover cables and estimate cable length too.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
kalvin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 36
전체 시간: 5,358
