주요 콘텐츠로 건너뛰기
A laptop by Toshiba in the L350 series with a 17" display, released in August 2009.
My computer shuts down soon after it starts up!
when i press the start button in the laptop it takes much time to open (more than 2 minutes) then it shuts down by its own i don't press any button
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Mine, if run on battery is won't shutdown but when plug it shutdown any solution pls
댓글 달기
답변 1개
가장 유용한 답변
When you write "time to open" I assume you mean the system boots up and loads your OS, but suddenly it shuts down. Is it correct?
If so, check you system fan, because the problem seems to be caused by an overheating and the laptop shuts down to prevent damages.
Other thing you can check is the thermal paste condition, or even if the heat sink is correctly screwed to the mounting holes.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
monet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 567
