주요 콘텐츠로 건너뛰기
A handheld digital pet that was first sold in Japan in 1996.
My Tamagotchi is still not working after a battery replacement?
I put a new battery in but it is still not working, so what else can I do so it can work and be played?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Seriously, what is the gadget you're talking about? Are you sure that the problem is the battery only? Please complete questions so that you'll receive helpful answers.
set it on fire....................................................
Why won't my tomogotchi work?
댓글 달기
답변 7개
선택된 해법
The mains problems with tamagotchis are :
  • oxidized pine (if you forgot the battery in it for 20 years ago… or buy it new. usually that’s not a problem with bandaï ones, but with odd pets) you can fix it by remove the rust with a q-tip with vinegar
  • bad contact from screen or battery . make sure the more screw you still have are well screwed.
Hope it will help someone
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
My tamagotchi is only 6 months old (the base). I had put a battery in, but it didn’t work still. I had put it in correctly and it still wouldn’t work. I had used a maxell battery
Not helpful whaler do you put it.
댓글 달기
I suggest making sure you inserted the battery in the right direction. I know this sounds like a simple thing, but someone I know did a similar mistake and ended up throwing it away when the solution was so simple.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Find the hidden reset button on the back its there somewhere
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Maybe reput the battery’s in if not get a box of new battery’s so it will work better 👏👏👏
이 답변이 도움이 되었나요?
점수 0
댓글 달기
this did not work! ahhhhhh
이 답변이 도움이 되었나요?
점수 0
댓글 달기
So this might be a bit obvious, but if your battery has a sticker take it off unless it says otherwise, because I didn't and i spent AGES trying to figure out what was wrong and then my dad came and took the sticker off and then it started working. So yea
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you. I did the same take the sticker off and it started working
댓글 달기
Well mine wasn't also working and got super mad so I just threw it on the floor and then it worked again
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Frog 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 75
지난 30일: 409
전체 시간: 13,226
