주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Black display frame for anti-glare model?
Hi,
I'm about to get the new MacBook Pro with an anti-glare screen. As I like the black frame of the glossy screens a lot more, I would like to know If you know about any replacement parts or any other ideas to get the black frame on a anti-glare screen.
Thanks for your help.
Fabian
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Take it off and anodize it in any color you like.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hi....
Your best bet would be to spray paint the silver frame.... (after you remove it of course) but the only problem is that it will no longer say Macbook Pro...
Please not that this and any modification WILL viod your warranty
Darren
Apple Certified Macintosh Technician
London, Ontario, Canada
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The "true" black frame is underneath the glass, so I doubt it would be possible to do it with OEM parts. It's not like the frame on the anti-glare, which surrounds the display from the outside (you can touch it).
Makes you wonder though... If the frame dimensions are similar, might it be possible to disassemble a glossy screen, remove the frame, and install it on an anti-glare? Might be a fun thing to try if you had access to some broken screens.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
"spray paint the silver frame"
brilliant
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Fabian Nagel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 9
전체 시간: 3,110
