주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Relaced screen assembly, now have a "grid" on the screen.
I had a screen that would come on and then go blank. The process looked like a combination of the beginning of the movie the Matrix and a laser printer that needs repair. I replaced the whole screen assembly and now the screen will come on, but there is a grid-like pattern on it. Also, any of the apps that are behind the grid pattern cannot be accessed. Any thoughts?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
This is often the case when either the display connections are not properly seated, the display itself is damaged somehow (Doesn't necessitate a break to the LCD or Glass), or unfortunately the possibility of a bad Logic Board.
I'd recommend double checking the Display connections to the board (You can test this by pressing with Some but not Hulk-Like force on the right top of the display) and see if that makes a difference. An odd point to note, but did any of the stand offs for the display cowling screws seem loose, or did they come off when removing the cowling? I've seen this occur and cause a grounding issue before.
My guess is Bum display, Or possibly a bad Logic Board.
To clarify the issue causing you to replace the display, the phone would turn on, but you would get no Image? Or would it turn on with an image, but simply go black displaying nothing?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had this problem after a screen replacement. I resolved it by double checking that the display connectors were seated, I also found I had mixed up the screws that hold down the metal cover over the display connectors, there are 3 different sized screws and they must be put back in the correct spots or they will not keep the cover plate snug.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hunter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 2,264
