주요 콘텐츠로 건너뛰기
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 질문 전체 보기
Bad Wifi reception after LCD replacement
I bought a HTC One M8 with cracked screen. Today i replaced the LCD and i notice very bad wifi reception. Did i damage something or forgot something?
I don't know where the wifi connector is located, and can't seem to find the answer on the internet.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
I have the same problem now. If you know what to do, please write it down
댓글 달기
답변 2개
hi
The problem is that you simply forgot to install the reinforced tape signal for Wi - Fi.
see photo ===>>
WiFi fix
https://s22.postimg.cc/islbn1s69/wifi_fi...
Thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Also this can be caused by damaged antenna connector or cable in case anyone wanted to know, but most of the time like you said forgot to put back the Wifi antenna cable.
댓글 달기
I need help. I changed display and i have poor Wifi signal. I connected all that needs to be connected. I think that i damaged cablr, but i don't now which one is for wifi. I will probably buy a full new set. Please if someone know which cable is for what text me. Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gregory 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 757
