주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
350 질문 전체 보기
GE Microwave Model PNM1871SM1SS running but no heat
I did search and found out that two common parts are magnetron and diode, so I spent $80 to replace them. However, replacement of parts did not fix the issue.
Before spending $$, any suggestion on what I should replace next?
Microwave is running fine with normal sound, but food is not heated. Could faulty door switch cause no heating issue?
I ordered capacitor next. If it doesn't work out, then will look into thermal cut-offs. What would be the best way to test them?
Thank you,
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
To keep door switches from failing, always press "STOP" button before opening the door. Yes you can just open the door and the oven will turn off but If you do the switch takes the brunt of any arcing type action.
댓글 달기
귀하의 답변을 추가하세요
Tim Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 5,647
