주요 콘텐츠로 건너뛰기
Model number TF700T released in July 2012. The Asus Transformer Pad Infinity is a Wi-Fi and Bluetooth capable tablet with a 10.1 inch screen and 8MP camera.
8 질문 전체 보기
Trouble getting Ribbon cable back in
I am trying to replace my cracked screen on my Asus TF700T. I can't seem to get the ribbon cables in far enough for the LCD to even work let alone the replacement screen. At first when I turned it on I could see the word ASUS really faintly. I turned the power off and tried to reseat the ribbon but now I can't see anything on the LCD. The LCD worked fine until I took it apart. Is there any trick to being able to slide the ribbon cable back into its connector?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
When you took it out did you notice if the port had a Horz. latch or the end snaps(?).
Make the cable as level and square as you can get and push in all the way. Most of the metallic contacts will be inside the port. It would help if you took Steve Martins advice and got "small" previously.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dvdmllreorders 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 472
