주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20001 질문 전체 보기
Keyboard keys not working
I have macbook pro, mid 2012. The key l (L) does not respond any more. the key o responds when ever it pleases.
No liquid on the key board, what so ever.
What can I do? Keyboard failure or motherboard failure? everything else works just fine
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 답변
Most likely just some dirt in the keys switch. Follow this YouTube vid Removing the key caps. Then using a slightly moistened cotton swab (Q-Tip) with isopropyl alcohol clean the mechanism just be careful as you don't want any of liquid from entering deep into the system here and don't want to damage anything by snagging anything with the cotton.
Lastly... You maybe posting too many LOL's :-}
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Thanks fr yur answer. But the keys L is dead for almost a month now and the o is abut fw suit, as yu can read. Cud a PRAM reset or SMC fix the problem, before I sent it to the Appe service? or ruin it with a jackhammer? I'm nt in the md.
SCORE
0
A PRAM or SMC reset won't help here. Cleaning will. If it doesn't work you'll likely need a new keyboard. If you don't want to do do this then I would bring it to Apple would be best.
These look like good places to start for Solotions. THANK Y0U!
댓글 달기
I have a similar problem. First my zero 0 stopped working which was annoying and then M stopped working. It wouldn’t type M when I press it but it will hide whatever I was working on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Murat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 32
전체 시간: 16,217
