주요 콘텐츠로 건너뛰기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 질문 전체 보기
Blank iPad not restoring, Serial Number n/a, "Waiting for iPad". Help?
Aunts 64GB Wifi iPad2 went blank, IOS unknown. Tried other cables and PCs. Antivirus disabled. iTunes recognises iPad2 but serial number n/a. Suggests restore so agree and iPad shows apple logo and progress bar. Progress bar does not progress and iTunes says "Waiting for iPad". Stays that way forever until unplugged when after a few minutes it goes blank again.
As it is outside warranty and paying for fix is outside budget, I opened it and reseated all connectors but this did not fix it. I Baked the motherboard at 250Deg C for 10 minutes but that did not fix it.
Is there a component that can be replaced to fix this? Or if I applied flux and locally reheated and reseated a specific IC maybe?
Basically, does anyone know what causes this fault so I can target a solution?
Thanks in advance,
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 1개
Hey,
I faced this issue about 2 years ago. to fix this, i tried multiple times to restore it and update, which fixed it,
Try to let it be on charging for 5 hours to go to 100% and then go ahead and try to do that 5-6 times and it shall fix it. or else, put it onto DSU mode and restore it.
5
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
H McSweeney 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 30
전체 시간: 4,686
