주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Laptop screen very dim
Can barely make out images on laptop screen. Screen displays fine on external monitor. Thought it was the inverter board, so replaced, but same problem. Replaced logic board, still same problem. Any ideas? Brightness is whole way up.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
If I read you correctly you have replaced the inverter board and the logic board. The unit functions well with an external monitor. It would seem that leaves only the cable from the logic board to the inverter board or the LCD itself. I would try the cable as the lower cost part first. I am including the link for replacing the LCD but hope you won't need it. Good luck Ralph
PowerBook G4 Aluminum 12" 1-1.5 GHz Display Replacement
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
댓글 달기
가장 유용한 답변
There's only the LCD & the Display Data Cable (LVDS) left and it doesn't sound like the cable.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I've got to learn to type faster. + Ralph
댓글 달기
답변을 추가하세요
sdheck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 1,471
