Does this look damaged?
Hi there,
my Iphone 5 went diving in our pool last week. It was underwater for about 2 minutes. After drying it in vacuum with rice, everything worked except for the display backlight.
So i opened the phone and found nothing suspicious except for this:
http://i.imgur.com/UManIFq.jpg
It looks like 2 "pins" are missing in the "connector sockets", can you see it?
Is it normal or am i right with my suspicion that it's damaged?
And if, how can i repair that?
Cheers, Eric
좋은 질문 입니까?
댓글 1개
Remove the board and the cover across from the board. Lets see what the components beneath it look like. Yes it does look like there are some issues with the pins, but it may be the image itself. Try to post a more focused one. Depending where or what is missing, you may be able to solder it with the right tools and skills. Besides the rice (which absolutely does nothing) did you clean it any other way? Did you replace the battery? What else have you tried? You did at least remove the board from the phone and removed the EMI shields?
oldturkey03 의
