주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 이 노트북은 Core i7 프로세서, NVIDIA 620M 외장 그래픽 카드, 1080p 디스플레이를 탑재하고 있습니다.
What to do when iSSD fails?
I have UX32VD.
I used to use my iSSD as a second storage partition. Now it died.
Until a few hours ago, I was running windows 10 preview. Here follows what I have done and my problem
1 - Removed the HDD and replace by SSD Saumsung EVO 850.
2 - Tryed to do a clean install of windows 10, it ends in an infinit loop and never reaches the installation menu.
3 - Tryed windows 7, the same problem.
4 - Tryed Ubuntu, it runned, showed several errors due to iSSD failure but installed and runs normally and very fast.
5 - Tryed to put the HDD with win 10 back, windows won't start.
My problem is the following, I don't want to be stuck with ubuntu, I think that I have not been able to install win due to the iSSD that is reconized by the bios that is already on version 214, the last one available on Asus website.
On ubuntu, sometimes iSSD is recognized sometimes not. But never I am able to edit partition or whatever.
If anyone can give me a hint on how to solve this problem. I have also contacted ASUS, but as my laptop is no longer under warranty I am hopeless on their solution.
Thanks for help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
Got same problem, I used it as Express Cache always. It started to take LOOONG times to boot (4-10 minutes depending if blue screen of the death appeared.
Sometimes the BIOS will show it, sometimes will show not all the info and sometimes any at all.
I fix mine today, read this:
http://cookuop.co.uk/asus-ux32a-not-dete...
and this:
http://forum.notebookreview.com/threads/...
If you need more images for reference maybe you should look at a video on youtube to see how it is UX32VD inside: https://www.youtube.com/watch?v=cqe1-X_k...
You got to open it with a Torx T5 and try to heat the iSSD a little if you can (though I think I could have saved that part during my fix). Next try to pry it open with some tool (I carefully used a knife) and screw it back again when finished.
이미지
This one is the enemy! Very little thing!
Suerte Samuel. I'm writing this on that PC right now ;)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Samuel Silva 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 9,663
