주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
9745 질문 전체 보기
Long Screws Won't Screw In!
Hello! I was recently opening up my Macbook Pro for the first time, and all was well, but when I went to screw everything back in, the back three screws (the long ones) WILL NOT GO IN! All they do is just screw in a tiny bit then get insainly difficult to screw in, and I don't want to strip them, so I pull them out. Please help ASAP!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 6개
P.S., The MacBook is from around 2011-2012 I believe.
What are the last four digits of your serial number?
Not sure how to find this @robert
It should be located on the bottom cover in this area
DV13 is the serial number. @robert
댓글 1개 더보기
댓글 달기
답변 2개
선택된 답변
It really sounds like you are talking about the bottom cover. With the machine inverted and the hinge facing away from you, the long screws go into the three holes at the top of the machine to the right. The far left hand screw in the back is a standard one. The short screws sound like you have them in the long screw holes. Gently lift the bottom plate up with your fingernails, as they really aren't attached and they should come out with the cover. Next time follow the guide.
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*MacBook Pro 13" Unibody Late 2011 하단 케이스 교체
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Are the screw holes I highlighted in blue obstructed in any way?
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I cant quite tell because unfortunately, now the other screws wont come OUT.
A few of them, at least.
The top right three screws won't come out. They aren't stripped or anything. They just keep spinning and spinning. But from what I can tell, the screw holes aren't obstructed.
The threads may be stripped, if you take a pair of needle nose pliers, can you get any leverage?
댓글 달기
귀하의 답변을 추가하세요
Kerp Kat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 14
전체 시간: 7,882
