주요 콘텐츠로 건너뛰기
파나소닉 터프북 CF-29 는 2004년 1월 1일에 출시되었습니다. CF-29는 군에서와 같은 가혹한 환경을 견딜 수 있도록 설계 되었습니다. Black Hawk CF-29 는 2009년에 출시되었습니다.
17 질문 전체 보기
Why is my hdd not booting or showing up?
I have a used Panasonic CF-29. It came with a SATA upgrade and a 80GB hdd. A couple weeks later it stopped booting saying "Operating System Not Present" and the bios wouldn't show anything under Master IDE so I thought the HDD had died. I swapped in a small SSD (128GB) and installed Ubuntu from a live-usb. EXACTLY the same thing happened "Operating System Not Found"
I've traded the SATA adapter, ditto on both drives.
The weirdest part is that no hdd ever shows up in the bios but will be visible later as a partitioned disk when I view it with Parted in Ubuntu. I can format and install Ubuntu to the disk but upon rebooting the same error appears.
Any ideas what could possibly be going wrong?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 1개
Don't spend any more money on a CF-29, it's not worth it.
댓글 달기
답변 1개
가장 유용한 답변
Change the hard disk legacy mode in you BIOS and reboot the system. try to install OS with Bootable Disk
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I'm not seeing a hdd legacy mode. Does this bios have a hidden advanced menu/mode like I've seen in other bios'?
Have you tried to update BIOS?
댓글 달기
답변을 추가하세요
Kris Jensen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,928
