주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
Battery percentage going down but its charging
my samsung recently started not charging properly. It is plugged into charge but as i use it the percentage decreases until it goes to 0 and shuts down. i left it in last night to see if the problem was me using it while it was in charger ( even though iv never had a problem with this before) and it only had 83% when i woke up. so i left it in for another hour and it was still on 83, i jiggled the charger then it started charging. What is wrong with my phone, is it the battery or charger.
Phone is fairly new ( 6 months)
Charger is original
Samsung Galaxy S3 Neo
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 44
댓글 37개
My samsumg galaxy tab 3 charging goes down when i'm playing a game or trying to watch something
my charging goes down while charging I have changed my charger nd usb too still I have facing the same problem plzz help me
My tablet is always going down when im blogging but it still going down untill shut down,but I'm charging it...pls help me out for tis...
I am suffering from same problem, I keept my cellphone in charging a whole last night but it remains in 83%, the red indicator can be seen and the sign of thunder is also visible but the battery is not charging and sometimes the battery percentage goes down, if the phone is fully charged after 2 or 3 minutes it decreases down rapidly.. Please help me what should I do
Maybe try taking out your charger and then putting it back and see if it works
댓글 32개 더보기
댓글 달기
답변 3개
선택된 답변
You said you have to jiggle the charger to get it to work?
If you have to wiggle/jiggle or biggle (my new word:) the charger in the port to get it to charge it's most likely losing connection to the traces on your motherboard. We've seen this a lot on the S3 in my store. If the charging port inside looks normal (no bent pins or damage) its possibly damage to the traces on the motherboard that connects the charging port to the motherboard. Unfortunately when this is the case I recommend another device or motherboard. You would basically need super human eyes to fix this part of the board. Even if you replace the charging port it might be a temporary fix if the connection to motherboard is poor/damaged.
I'd first inspect the inside the the charging port (see if there's any visible damage). I would say try a battery or another cable but if you have to adjust the cable, it prob won't work. I'll upload a picture of what I'm talking about soon.
해당 답변은 도움이 되었습니까?
점수 16
댓글 11개:
i have problem my Samsung s4 charging with adapter 1 amp it take 15 hour. and when i put data cable to cpu showing charging but charge level is go down. so now i use different camera adapter 2 amp. please suggest to me
im using Samsung grand prime i bought last week but it give me a problem when it comes to charging it made 70% and they dont want to go up and from the it starting to go down
My Samsung galaxy on5 is not charging properly ok so I plugged it in with a different charger and the battery percentage is decreasing. why is it doing that and how do I fix it
The s3 charge port is part of the motherboard unlike the s2 which were 2 different components
My s5 looses battery life quick because when I first got it I didnt charge it for 8 hours any fix?
댓글 6개 더보기
댓글 달기
faulty battery , If phone is as old as stated you should have manufacture warranty
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
My one I got 8 months ago and it only just started to do this even when it's off
this is the second time i have this problem but warranty takes two weeks to send you another device at least with ATT this is the case so you end up buying this junks over and over
Just close a bunch of apps down in your settings. Mine was doing the same thing, forced stopped a bunch of apps that weren't needed and it's started charging properly again. Hope this helps!
댓글 달기
I'm an electrical engineer... The problem, more than likely is the c-type connector head (the end piece that plugs into your android phone). The trace pins are precision soldered with a wave machine to the specific pin contained in a wired harness. If you happen to drop the phone in any way on any surface at any distance, it's quite possible to damage that precise harness inside the connector head causing the power dissipation of the battery due to the current now being unconditioned. This is a safety feature so as to not explode the phone's battery when those trace elements are damaged. (it's like the surge protector in the cable is broken) I'd recommend getting a brand new undamaged cable and reboot the phone before charging, this in all likelihood will fix your issue but I'd definitely stop using that cable. You'll eventually burn out the elements in the adaptor (the pronged piece you plug into the wall outlet) too causing it to be bad and then you'll end up damaging any new cable you plug into it. GO WITH A HEAVY GUAGE BRAIDED CABLE WITH HEAVY DUTY GROMMET CONNECTOR ENDS ON BOTH THE USB AND THE C-TYPE HEADS. (you can get fairly good ones on Amazon)
SIDE NOTE: charging cables were designed to be used when the phone battery is fully discharged and would require the phone to be in a stationary horizontal position with zero cable bend even when using it with a laptop as a data transfer cable as well. (this means learn to stop talking or operating the device while charging for best results... the cables will last much longer that way)
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I will try yours and will see, it seems logical to me.
I use my tablet specifically for games and if I don't keep it plugged in I spend more time charging than gaming.
Yea try this ur ideal✌️✌️
댓글 달기
귀하의 답변을 추가하세요
burgerandfries 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 41
30일 전: 180
전체 시간: 329,190
