주요 콘텐츠로 건너뛰기
Replacement of hard drive with larger capacity cause issues?
Hello! I need to replace the HD in my iBook G4 12" 1.2GHz 30GB HD. I'm looking at buying your IF107-069-1 (320 GB 5400 RPM Western Digital ATA Hard Drive). If I replace my HD with a larger capacity HD will I loose any functionality?
Also, is there a larger or faster RPM HD for sale for this model? The reason I ask is because I once tried to replace the HD in a G3 iMac with a non-approved HD and that iMac would no longer go to sleep.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Colleen, thank you for the prompt response!
If Colleen's answer helped you, you should accept the answer. If you're still not sure of a resolution, at least vote her post up.
댓글 달기
답변 1개
선택된 답변
I haven't had any problems with replacing these hard drives. Anything ifixit sells for your model should work just fine.
I think size is more important than speed. I stuck a 7200rpm drive in my MacBook but haven't really noticed any difference.
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
Just had 10.4 installed on my iBook with the 320 GB Western Digital hard drive I bought from iFixit.com. The WD works well and the computer goes to sleep as usual. Thanks for your help Colleen!
I agree with Colleen. Especially with a G4, hard drive speed is not going to be the bottleneck, as long as you are at 5400RPM or faster.
댓글 달기
귀하의 답변을 추가하세요
Stafford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 3,549
