주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Black screen. External monitor working
The Mac starts up and runs probably on thunderbolt to vga adapter but the built in screen remains black. It has an AMD HD 6770m graphics card so not the one under the repair program.
Any ideas what could be the problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
To be clear here: You are able to run your system via an external monitor - correct?
Can you give us the last four digits of your serial number so we can identify which model you have.
Yes the external monitor works.
DHJP
댓글 달기
답변 1개
가장 유용한 답변
See if you shine a flashlight into the display at a sharp angle if you can see the faint image of your desktop & an external display works, then you know the LCD's backlight services needs repair.
But, ... Without knowing which model you have I can't tell you more.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Yes there is faint image. I thought there wasnt but i managed to log in and see the dock.
The model is A1312
EMC 2429
Im leaning towards the backlight inverter but not sure how to test this?
I've had a few LED driver board go on me. Here's the IFIXIT guide to get to it and replace it: iMac Intel 27" EMC 2429 LED Driver Board Replacement
I've ordered the board. So I will see how that goes when I get it. I'm sure I will be back on here if all goes wrong.
Thanks for your help.
Take your time and don't force things as some of the connectors are fragile!
댓글 달기
답변을 추가하세요
lcrooks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 1,226
