주요 콘텐츠로 건너뛰기
Apple은 단일 알루미늄 블록으로 가공한 새로운 알루미늄 케이스를 사용하여 MacBook Pro 15" Unibody를 출시하였습니다.
3092 질문 전체 보기
Why is my wifi icon and hardware missing?
I have a macbook pro 5,3 15 inch unibody mid 2009 on Mavericks and the wifi is not working ...The icon does not show ,I tried to create a new network in system preferences and the wifi option wasn't available, I click network diagnostics and the wifi option was grey. I believe it's not hardware because in the beginning wifi was good when my hard drive was wiped that's when it occured
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Hey! You must make sure drivers for wifi card is installed on your macbook fully, becosse problem after HDD replacing...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Where can you find the drivers to install ?
@emailgregnow - Sadly, this is not the correct answer. The drivers are part of the OS-X so simple act of installing the OS you get what you need. It sounds like you have a hardware problem like MichaelJrRekson has. There is a few things here you can try to fix this. I recommend you create your own question with all of the details so we can work it out with you.
댓글 달기
귀하의 답변을 추가하세요
MichaelJrRekson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,898
