주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 질문 전체 보기
Suction cup won't stick?
Hello, I am attempting to repair my iPad Air Gen 1, and the suction cup won't stick enough to pull up the adhesive. It's cracked so badly (spiderwebbed) that without the tape, the cup only cracks the screen further.
Any suggestions? Thanks very much.
Cody
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
I usually apply transparent tape all over the broken areas.
Nonetheless, the suction cup will still not hold. You just have to do without it. Lift the edges of the digitizer using a thin tool such as the iSesamo then insert a guitar pick or credit card and run it along the edges while watching out for the flat cables and antennas. Follow iFixit's guide and you'll see where they're located and what to watch out for.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Lots of heat, iSesamo, and patience.
Take your time getting all the glass up, be careful around the connectors. Airs are a pretty straight forward screen replacement if you take your time. Heat an area, use the iSesamo to pry up the glass, move to the next area. Take it an inch at a time. Once you get the glass up, use Goo Gone and IPA to get the adhesive off.
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Follow the step by step instructions on here very carefully. You are going to need some heat to loosen the adhesive and something to jimmy between the glass and frame to lift the glass.
I also recommend watching videos on you tube on how this is done. I'm thinking that this may be your first ipad repair so be patient and careful. Things can escalate quickly if you aren't ...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Other answers here are spot on. Usually some clear packing tape will do the trick though.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
morganbaritone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 1,752
