주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
driver power window not working
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
First check the fuses.If that's ok pull the door panel off and check the switch for power if the switch is ok then check your wiring from the panel out. If there's a break in the wiring its usually in the door hinge area where the wires pass from the body into the door. If all of this is fine and you have power all the way down to the power window motor yet you still have no Joy then you will probably need a new regulator motor. Hope this helps and good luck
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
wayne doak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 21
전체 시간: 426
