주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Can't restore I pod-tried everything
Here is what happened. I dropped my I pod from maybe about 2 feet, when I used it shortly after I noticed that it was pretty laggy.
Within 20 min or so it shut down and tried to powerback up but kept trying to shut down, turn back on. Eventually I got the notice to connect to iTunes to restore. When I do that it says unknown error cant restore (1436). I have also tried going into the properties of the disc but also get an error message saying windows can not access the drive.
I have installed the latest iTunes, uninstalled, installed an older version, uninstalled, installed the newest again. I also have tried holding menu and select a thousand time as well as tried resetting through disk mode and nothing works. Any ideas??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
nattyjay, could be a damaged hard drive. Try the diagnostic menu and see what shows up. Here is how to do it and what the test results mean. Let us know what you find.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
nattyjay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 132
