주요 콘텐츠로 건너뛰기
The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
30 질문 전체 보기
Why does my beats pill only work when it's plugged up
My beats pill only works when it's plugged in once I take it off the charger it doesn't work no matter how long its been charging
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 16
댓글 1개
If the motherboard has a little corrosion do I need to replace it?
댓글 달기
답변 6개
가장 유용한 답변
Shakim Prince, double check to make sure that yuor charger works and that your cable connector as well as the charging port are without any damage. Check for bend, missing or corroded pins. If you find all that in good order, it is entirely possible that your battery is no longer holding a charge. Use this guide to replace the battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Is your battery showing 127%?
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I have this problem 127%
I have this problem, how do I fix
same problem here
댓글 달기
My battery is showing 127% and it won't work without charger. How can I fix it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
no one has answers, same here 127%, fmk!!! i CAN'T FIND A REPLACEMENT BATTERY ANYWHERE
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is because if you play music or audio while you have it plugged in it will ruin the battery. If you want to fix it what you need to do is take it apart and buy a new battery, but I will warn you that the battery is hard to get to, and you have to carefully move everything inside in order to get to the battery. You also have to be carful of the speakers because they are magnetic and as you remove the tiny screws connected to the battery they will hit it and it can break the speaker. Depending on what type you have will depend on what new battery you get. You can also try to reset the battery to see if that works. I will warn you that most of the batteries I have seen online are expensive. Well, I hope you can get it fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You need to get a battery replacement had the same problem with mine just replace the battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shakim Prince 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 131
전체 시간: 43,764
