주요 콘텐츠로 건너뛰기
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40 질문 전체 보기
horn repair and airbag light is on
My airbag light is on and my horn does not work, they both failed at the same time,
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Sounds like you need to replace the clock spring Its the wire harness that keeps your wires conected as you turn the steering wheel.
https://www.youtube.com/watch?v=VxYHC6oX...
This is a brief tutorial on replacing one. Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
check the airbag clock spring...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It's the clock spring I figured it out after i reset my dash lights three times and it illuminating my airbag light..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
argyjpolsinelli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 16
전체 시간: 7,870
