주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3787 질문 전체 보기
After replacing the screen on my Macbook (2006 model), it flickers
My screen is flickering and scrolling after being replaced. Soon after replacement (I replaced it with a LG screen), the screen was fine and everything checked out. But within the hour (I didn't use the Macbook during this time, it was charging)...when I opened the Macbook to start work, the screen was just randomly scrolling and flickering!! Help!! I can't spend more money buying yet another screen....what could have gone wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
1. You have a loose connection, check this by opening and closing the macbook. If there are changes in the intervals of flickering you may just need to check your internal connections.
2. The Display Data Cable is damaged. (Causes Screen Defects, its possible you damaged this with the LCD replacement.)
- You can check this cable by looking for cracks or tears in it.
MacBook Display Data Cable
3. Your old LCD was fine and you have a bad Display Inverter.(Unless it was cracked, Please specify why you replaced the screen.)
MacBook Display Inverter
3. You have a bad replacement LCD. (If its bad it could cause flickering.)
4. Give us a little more information about your macbook model, and what you have attempted so far.
Good Luck, and be sure to give us some feedback.
-Varsity
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
vaidehee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,726
