주요 콘텐츠로 건너뛰기
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 질문 전체 보기
Why does my screen stay black?
dear fixers,
I recently got a Galaxy Tab S but the screen stays black.
I do feel vibrations and hear sounds from the machine.
The tablet hasnt fell or anything like that.
Anybody has experience with this problem, or can anybody tell me how to fix this myself?
Kind regards,
Soester
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 10
댓글 달기
답변 3개
try to reset your phone
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Did everything like holding the powerbutton + holding the - volume, i feel it fibrating but screen doesn't respond to anything.
Although when i repeatedly hold the powerbutton and the - volume. The blackscreen give a white flinch
댓글 달기
Most likely the ribbon cable for your screen might have come off the connection. My tablet is currently doing the same thing, so I am going to take it apart and check it out and try re-connecting it. I'll let you know how that goes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
So as I mentioned about the ribbon cable. I took it apart and disconnected and then reconnected the ribbon cables for the screen and powered it back on and works perfectly.
댓글 달기
If the screen ribbon Cable doesn't fix it. Check the cable with 5 wires going to battery it's in the center in between the batteries. Disconnect it leave it off for 10 seconds reconnect it. Then power on while holding the volume button and then reboot normal.
It's some &&^&@@ up bug on this tablet which sucks because otherwise it's an amazing machine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Soester 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 3,320
