Why does my sump pump only last about a year?
My sump pumps go out after about a year. They run heavy during the spring but not that much during the summer and winter. I have tried numerous brands including one with a lifetime warranty and one rated for continuous running. Still they only last about a year. Any ideas? Could there be an electrical issue?
좋은 질문 입니까?
댓글 3개
We need to know what's going out on the pump.
mayer 의
This may sound a little obvious- but are you sure something's wrong with the sump pump? Or have you just needed to charge or replace the battery? If you've never replaced or charged the battery then that would be the most likely cause.
rab777hp 의
Is there a weep hole above the pump, but below the check valve?
How high is the lift?
What brands have you tried?
Are you buying at a big box store?
Are they made of plastic?
Have you tried a Zoeller cast iron pump?
Bryce Nesbitt 의
