주요 콘텐츠로 건너뛰기
대부분의 태블릿 컴퓨터 수리. 태블릿은 크기가 작고 빈번한 접착제 사용으로 인하여 태블릿 수리는 노트북 수리보다 더 까다롭습니다,
18921 질문 전체 보기
질문 마감됨
replace lion battery on the tablet
I have a cheap tablet that its battery has died. I want to replace the battery with some better brand like the redmi phone lion battery 3200mAh by connecting the terminals on the lion battery with short wires. But it cannot adhere firmly using adhesive tapes.. Is there any way you can think of so I can make the connections without doing any soldering? I do not want to damage the battery.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Can you specify the tablet you have? Also go check out the Dell Laptop response I wrote back to you.
It is not needed to know what kind of tablet, providing that the battery will have two leads , one positive and one negative, that connects inside the tablet. The redmi phone battery have 4 terminals, the middle two can be sealed with adhesive tapes. The one I have is original a lithium polymer battery, which is soft. the redminote phone has a hard case, however.
댓글 달기
답변 1개
go to https://www.youtube.com/watch?v=-IDILj2c...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 124
