주요 콘텐츠로 건너뛰기
G4 Quicksilver는 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, 그리고 1.0GHz 속도로 출시되었습니다.
20 질문 전체 보기
need replacement fan, behind modem, ethernet etc
I need a new fan, but I don't know the part number (or where I can get one) - or what this particular fan is called so I can order a new one? I looked at the teardown and by removing the two screws next to the ethernet, usb, firewire etc., ports on the back I can remove and replace my now very noisy fan which is on the other side - it just started getting noisy a week ago. Thank you! jon
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
You're probably talking about fan part number 922-3295
Here's a parts teardown: http://ep.yimg.com/ca/I/lovemacs_2113_43...
Here's links to the part:
http://www.allmac.com/shop/product_info....
http://www.mac-pro.com/s.nl/it.A/id.2239...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
댓글 달기
hmm, actually I don't think that's it - this chart is really cool, but it's showing an earlier G4, not the Quicksilver - and the fan doesn't look correct. Mine has a chunky black case. But thanks for the effort. jon
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
there were two versions of the 733. Both used the same fan. See if this looks right: http://ep.yimg.com/ca/I/lovemacs_2114_10...
I ended up ordering cpu fan #2410ML-04W-B47 off of ebay, It looks to be the right fan and it was only $10. Thanks - jon
댓글 달기
답변을 추가하세요
jon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 986
