주요 콘텐츠로 건너뛰기
Repair guides and support for smartphones in the Curve line produced by BlackBerry since 2007.
My BlackBerry Curve 9320 phone is not getting started...
my phone is not geeting started after software upgrdation ...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
I had the same issue and fixed it with a hairdryer! Try taking out the battery, blow drying it for a little while on all sides. Then blow dry the keys of the phone and inside where the battery goes. I don't know why it worked but it did. I assume there was either dust blocking connections, or some moisture causing issues.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hello Hari Saladi ,
it is very easy to fix your phone. case is the firmware not update properly
Use this line to download JL commander
  • install jl commander
  • connect your blackberry to pc via USB cable
  • select option 5 (reset to factory defaults)
  • your phone will be restart and hangs with error on white screen
  • install blackberry desktop manager using this link
  • update software gain
after updating the software you can use your blackberry with better performance ever !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hari Saladi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 527
