주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
Micro-USB power port is broken
After only two weeks, the HTC Evo's micro-USB power port failed, maintaining a connection only when I press on the connector in one specific position. I can pay Sprint $120 for a new phone (They won't cover this kind of damage, even though the problem is an obvious factory defect or design flaw.), or I can send it to HTC for repair (paying for outbound shipping and waiting up to 10 days to get my Evo back). How difficult would it be for a non-expert to resolder the connector?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I don't know about soldering; I had the same problem, sent the phone to HTC and they claim that they need to replace the entire main board and want to charge me $240. (Even though the port broke in about two weeks of normal use). Of course, that's nuts; the product is obviously defective (by design or engineering) in that it can't withstand normal wear and tear. Whatever you decide to do, don't send your phone to HTC. Even if you decide not to let them repair it, they'll charge your credit card with a $39 "triage fee." Unbelievable. My first -- and last -- HTC product in a space of a month. Next stop... the California Dept of Consumer Affairs to try to get a refund.
댓글 달기
답변 10개
선택된 답변
If you can push on it and temporarily resolve the problem, it sounds like a bad solder joint or broken trace. If it is either of these problems, buying a new socket isn't really going to help the problem and will only add unnecessary work. Prior to buying a new socket, try reflowing the solder on the existing socket. Perhaps add a little more solder if there doesn't appear to be enough to hold the socket properly.
Remove the motherboard from the phone. Clean the board around the socket and solder joints good with Isopropyl alcohol that is at least 95% pure (or as close as you can get to that). Flux is your best friend for this type of work. It pulls the contaminants away from the joint and existing solder. It is the contaminants that prevent proper heating during the soldering process. Apply flux to all the solder joints of the socket and reapply as necessary to each pin. As you work your way around the socket, heat the joint until you see the solder "wet", then remove the soldering iron from the pin. Clean the flux off the board and socket with either isopropyl alcohol or water depending on the type of flux you used.
If it is a bad trace, carefully clean the "shellac" (coating) off the copper trace on either side of the break. Use a silver trace pen to connect the 2 ends. Test. After you are satisfied that the trace is repaired, use an overcoat pen or a small amount of clear fingernail polish to cover the exposed trace so nothing can short it in the future.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I ordered a replacement microusb port off of ebay that belongs to a blackberry, but it looks to have the same mounting points as the one my EVO used. I will be attempting to replace my broken port. The previous microusb port lifted right off the traces (fortunately, without lifting any traces); it seems that the solder used to hold the port in place was not strong enough to take the constant pressure that a charging cable would induce when connecting/disconnecting. I am used to working with SMT components when it comes to soldering, and I do not have any fears about the actual soldering; however, i am concerned about the amount of space I have to work with. It looks like in order to get access to the pins that connect to the traces, I will need to remove the vibrating motor in order to get enough room for my soldering tip to access the pins of the microusb port.
Any tips on how to remove the motor would be appreciated. I have a 25 watt desoldering gun, which may be too hot and I also have desoldering braid.
댓글 달기
i have a question to add to this thread. i'm not a "NOOB", per say, but i've never dealt with a partially working charge port. my evo will charge all day, and fully at that. my problem is that when connected to my pc, it charges, but does not recognize that a computer is supplying the power. could this be a bad power inlet? i've tried several different cables, to no avail, and i'm very tired of shutting down the phone to put new files on the sd card, and my neighbors are getting annoyed that i keep using their internet. any help would be greatly appreciated. good luck to all of you on your problems.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Ok guys,I have been repair micro usb ports on the Android phones for a while which is an easy repair.The only problem on some Android devices even replacing the port may not fix the problem,because some device has resistor that control the charge circuit,so if the resistor has a bad reading it will not accept a charge.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I went on ebay and bought a few "Micro USB B Female 5Pin SMT Socket Connectors" for about $5. I'm now in the process of soldering the new connector on. I find that the hardest things to do are:
  1. getting and keeping the connector aligned while soldering
  2. positioning it so the connector has a good connection with the motherboard.
Don't be fooled into buying a new soldering iron with a smaller tip. Yes, it would make it easier but it is not really necessary unless your current soldering iron tip is a medieval sward.
There are external chargers for the evo so charging is no longer an issue, the problem is I still want to be able to sync it with my computer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
You mentioned : There are external chargers for the evo so charging is no longer an issue, the problem is I still want to be able to sync it with my computer.
what kind of external charging devices are there? I am not interested in syncing just CHARGING. and the mini usb socket connector just fell out. So right now what i'm doing is swapping with a co-worker at work batteries. but as you know it doesn't hold a charge for long. Also what part number is the mini USB connector, I tried to order one, but they told me, that I needed a part number to order the right one.
Is there any way to charge the EVO 4g a back way through the HDMI connnector port on the phone?
There are charges on eBay for the evo. Some include extra batteries which is nice. I decided to get the extended battery packs and charger for now; I really like them. I got them for $14 including shipping and it came with an extended phone backing plate, extended battery packs, a external charger. The backing plate is a little difficult to get off but that can be fixed by filing the tabs on the back at an angle so they slip off easier. I honestly don't know about charging through the HDMI port. I did find the proper connector on globaldirectparts.com however they are out of stock at the moment and they don't know when they will get more. Last but not least, I saw a site that was called www.missionrepair.com who claim to fix the port for around $50 or $60. I may look into that if needed.
RadioShack has one that works well. You do need a spare battery and charge and swap. Got me through a LONG week of problematic charging port issues.
Replacing batteries is fine as concept, but then one needs to shutdown the phone. It is still better to have charging properly working.
This is until whole industry realize that no socket is good and we have edge contacts that can be easily maintained.
댓글 달기
I got a micro USB female socket from mouser electronics for a whopping 43 cents. lol
It was "wave soldered" during assembly, so forget about conventional soldering .
Im an electronic technician, engineer, and a ham radio operator... and this is one tall order.
The way to kill this bird is not with a soldering iron, but with a heat gun...and not just any heat gun...one specificly for tiny surface mount electronic repairs. The one I used was attached to the end of a butane fired soldering rig, and keeps direct flame away from target area. Heat the metal jacket gently while lifting the socket assembly upward, away from board surface. When solder melts enough, it will let go. Then clean gently and inspect the board surface for debris or any "bridging". Since the thing was wave-soldered originally, chances are there wont be satisfactory amount of solder left for installing the new socket. What I did was prep the socket terminals (freekin tiny row of 5 little brass stubbs) with a thin application of fresh solder...after warming it up and applying raw soldering paste (rosin) 1st. This prevents bridging, and is almost guaranteed to screw you up if you dont rosin it up 1st, as the little pins (stubs I call em) are so close together and will cause too much solder (as in, a speck more than the one speck required, lol) to cling to them, causing ... (drum roll) ... bridges....(another drum roll) ... and failure.
So all thats left after pre-tinning the new socket pins, is placement againt the PCB and then take a little (tiny) vise clamp, or any tiny metal clamp (alligator clip worked great) to squeeze the socket down against the target area while re-heating assembly again in a reverse operation of the dis-assembly.
Then , after maybe some prayer, or meditation, or ... for some folks .. a sacrifice of a small animal or three, ... You can test your work. I recommend not neglecting to make sure that on each side of this socket assembly you manually solder a decent bead of "mechanical solder support" on both sides (right and left)
This is required for "mechanical" stability of the plug itself, and not really an electrical connection, besides the fact that it does indeed provide a ground for the outer metal sheild.
If you dont solder the two corners down, you can count on the other tiny little heat-gun bonded solder joints you took so much pains to do correctly, absolutely peeling back off the PCB the 1st time you stress that socket with a USB plug or charging dongle.
If you cant comprehend the layman terms used in this description (or you have never soldered anything small before) ...totally forget even contemplating this kind of repair. You will fail before you even start.
Update
Mouser electronics
part number - 649-10104111-0001LF
price (43 cents)
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
if you don't mind, could you point out which part you got from mouser? I ordered 3 different sets of top mount assembly micro usb B connectors, but none of them would fit perfectly. It struck me odd that HTC would use such a relatively hard to obtain part (I guess it doesn't matter when youre buying 100s of thousands at a time...) I definitely agree that a heatgun needs to be involved, but I am looking for the perfect part before I can fix that extra broken EVO i have.
Thanks for your response, and I would definitely appreciate the part no.!
Thanks!
649-10103593-0001LF
this is the correct part, disregard the previous #....it requires a "reversed" socket schema....the 1st part # was for a standard version.
Sorry if I made you waste your 43 cents on wrong part, LOL
By the way, mouser has over 9000 of these in stock, right now!
woot
649-10103593-0001LF is not correct. this is not the required reversed connector its another standard one. do not buy
The thing that sucks is that if looking at Mouser 10103593-001LF shows one thing on the picture, but when you click on the data sheet, it shows the part you actually need...look carefully though, you'll see that even though Mouser has the part as 10103593-001LF the data sheet is for 10103592-001LF...bought 5 of the 10103593-001LF, and they were wrong, $12 down the drain.
DigiKey sells the 10103592-001LF in singles...instead of Mouser's 9600 piece minimum...
댓글 달기
Wow! I know you're gonna believe this (bc its not unbelievable) but I opened up my evo & placed a piece of an eraser from a pencil on top of the usb thingy and it works fine. Only cost me $6 from buying a torx screwdriver set. It's set firm and doesn't wiggle anymore. woo-hoo! smb htc & sprint!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
great temporary fix, but I am certain that this will degrade with time. Follow ABCellars advise and fix it permanently :-)
댓글 달기
Unfortunately, this is a common problem for that model phone. The micro usb is a poor design in my opinion. I would be content with mini usb connectors. Anyways, if you know someone who is experienced with soldering you may be better off getting a new replacement. Just in case the USB is not defective. By the sounds of it the inner pins could be bent if you had to push it a certain way to get a connection. You can get a replacement connector herehttp://cgi.ebay.com/USB-CHARGING-SYNC-PO...
Still I would only recommend someone who knows how to use a solder iron or heat gun perform the repair. It may cost a little bit but it will likely be way cheaper then $120.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
== STOCK HTC CHARGER
i had been using another charger for my phone other than the one that came with the phone, well i had mindlessly plugged in my usb charger into my phone to transfer songs to my itunes, as soon as i remembered that my port was broke, the option screen pops up weather to tether, usb drive, charge only ect... i was stoaked, but before getting totally excited i pulled out the wall adapter and plugged the usb cord and it still worked.
I had tried 3 store bought chargers pryer and non-worked.
being absent minded for a second saved me $100 lol. ==
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
had the same problem with the port breaking. bought an extra battery and a battery charger so i just swap the battery when needed. if needed i have a sd adapter to put the micro sd card right into my laptop to down load pictures.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I've had the same problem with my HTC EVO 4G, the usb port actually broke off of the logicboard. I opened the phone to see if I could fix it and it simply fell out! For anyone who needs to charge the batteries there is a way around it that has worked well for me. However, the phone MUST BE TURNED OFF WHILE CHARGING. If you turn it on while using this method it might fry! Also, I wouldn't recommend walking away from it while it is charging, because the battery will get very hot and if left for too long could explode, catch on fire, etc. Basically you take a usb cable and strip it(not the end that goes into the computer, keep that intact), you will see 4 wires inside - Red, Black, Green and White. You can cut the green and white off, we are only interested in the red and black. Red is positive, black is negative. On the battery you will notice a positive and negative symbol. If you are looking at the back of the phone with kickstand closer to you, camera away from you, the far left prong is positive, the far right is negative. Simply remove the battery, place the red wire in the far left and the black wire in the far right(MAKE SURE THEY ARE ONLY TOUCHING THEIR RESPECTIVE PRONGS!) put the battery back in then plug the usb into your computer. Some have warned not to use a usb charger that goes into the outlet, however the outlet works best for me, it gives me a full charge in about 10-15 minutes! The usb port on a computer will take an hour or two. It is clearly safer to use a computer, if you use an outlet, watch it carefully!! Using either can cause excessive heat on either the battery or charger, so again, monitor it carefully! Your phone's charging light will not come on, but trust me, the battery is charging. This is definitely a MacGyver/Survivalist way of charging your phone and quite frankly is pretty !@#$ ghetto, but it works for free. It's very simple but use caution, I suggest plugging into a computer to be safe instead of the outlet and again, do not leave it unattended or leave it on for too long(no more than 2 hours from a computer, or 15 minutes from an outlet). And if you need more instructions simply search youtube for "charging an htc evo without a charger" and a few decent videos should pop up. Hope this helps someone!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Goober Mayberry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 25
전체 시간: 88,322
