Extremely short battery life
Battery is not lasting more that 5-6 pictures.
좋은 질문 입니까?
Two possible fixes.
(1) reset camera
remove batteries
hold down power button for 1 minute
replace batteries
(2) increase battery contact pressure
remove batteries
using needle-nose pliers, bend battery contacts (in battery case cover) to better contact batteries
replace batteries
해당 답변은 도움이 되었습니까?
By default, as soon as you turn the camera on, it enables flash--even when not needed. Form this habit: As soon as you turn the camera on, every time, press the "up" arrow on the four-way pad to turn the flash off.
Not only will the batteries last much longer, but the camera will be ready to take the next picture much more quickly.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 5
30일 전: 23
전체 시간: 1,406
Do not use Alkaline AAs in a camera. You need rechargeable NiMH (Energizer seem the best). Or use Lithium AA one-time batteries (expensive!).
Rechargeable AA NiMH are best. But this is not a new camera, the A720. If you are using rechargeable batteries and this problem is new, it may be time for new camera.
Brian Reeder 의
