주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
281 질문 전체 보기
질문 마감됨
What is the chipset?
What is the chipset? (Intel H97 or Z97?) And why wasn't it revealed during tear-down?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
H97 and Z97 is made for desktops.
If i'm not mistaken, the chipset is included in the CPU package.
If you're not satisfied, you could have a look at other Core-M powered laptops on the market, to see if there's more info.
Fx. Dell Latitude 13 7000 , HP Envy X2, Lenovo Yoga 3 Pro or Asus Zenbook UX305.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Here's a good writeup: Trusted Reviews
댓글 달기
MorbidMylar, you are right. I just did some research. For this Broadwell-Y, on the CPU package, there are two dice:
  1. the larger long die contains the CPU and GPU, made in a modern 14 nm process.
  2. the other smaller die (almost square) is the Platform Controller Hub (PCH) in a low-power version made in a 32 nm process. This PCH die essentially is the "chipset" and typically refered to as "Broadwell-Y PCH-LP".
Together, they form a SoC. For Broadwell-Y (TDP around 5W) and Broadwell-U (TDP around 15-23W), this SoC configuration was chosen by Intel.
For the Broadwell CPUs with Broadwell-H and up (these are desktop CPUs which may also appear in notebooks with fan-cooling), the PCH is not on the CPU package, but the chipset (=PCH) remains on the mainboard in a Z97 or H97, or HM87 or HM97. In those cases, where there is a second die on the CPU package for these desktop CPUs, it is the eDRAM of the IrisPro graphics GT3e.
Used sources:
http://arstechnica.com/gadgets/2014/08/b...
https://software.intel.com/sites/default...
http://www.notebookcheck.com/Intel-Broad...
Actually all these concepts had been part of Haswell CPUs as well.
http://scr3.golem.de/screenshots/1402/En...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 606
