주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s bottom microphone not working on call and voice memo app
Hi I've been having a problem with my iPhone 5s bottom mic after replacing the battery. It doesn't work on voice memos and people who calls me says that they can't hear me when calling. Is there any way to fix this? Also I did try hard reset, replaced the bottom mic/lightning connector but I still can't find the solution. I also made a research about how to make the mic going it said that to put some kind of card on top of the IC audio whatever that is to put pressure on it but I don't know if it will fix it because I never wanted to open my iPhone again because I might damage some other things in it. And I found another research saying that to check the capacitors of the mic if it's damaged etc. but I don't know where it's located at.
UPDATE
I just opened the my iPhone for one last time and I saw that a tiny capacitor (if that's what you call it) next to the battery connector, the 3 capacitors on the far right handside, the middle one came off. Do you think that capacitor has something to do with the bottom microphone?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
try changing your 5s charge port. the charge port controls the mic and speaker for memos ring tones, music, etc...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
the charge port flex cable? Yeah, but I just changed that 3 days ago and still it doesn't work like it used to be.
And everything on my phone works fine after replacing the charger port flex cable except the microphone.
댓글 달기
I believe the mic on the front camera flex acts as a noise cancellation mic. Try a new front camera assembly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Mic next to front camera works when I take a video.
well then it sounds like a motherboard fault ! sounds like something on the logic board could have broke off or could have damaged when dissembling
댓글 달기
귀하의 답변을 추가하세요
EJ 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 3,245
