Is it possible to replace just the glass on the S6 Edge?
I cracked my glass within 3 weeks of buying my S6 Edge and I was wondering if there is a way to replace just the glass. Not to brag, but I'm a real techy guy and I've done other screen replacements in the past. I did a glass only repair on the s5, and from the pictures I've seen, the lcd is bendable on the edge. Will this still use LOCA glue and a UV light? I've got the tools, I'd just need to buy the parts. The glass is very cheap but the lcd and glass combo is over $200. Just wanting someone else's input before I go into something that could be way over my head. Thanks in advance! :)
좋은 질문 입니까?
댓글 22개
Yes, You can but be very careful not to use too much heat and don't puncture the battery!
I just replaced glass only on my 925t
Difficulty level; high..
David Rudolph 의
If doing glass only why would you even be close to the battery!?
Rob Blank 의
You can not get the glass off with out taking the battery out. It is a process. Don't we all wish it was that easy though. Just simply take the glass off lol.
DERRICK CEDENO 의
Battery has to come out because of heating glass. Don't want to expose to too much heat
T Payne 의
Can i do it in my s6 edge+ ? Where can i buy glass ? Thnx
eurogoni 의
댓글 17개 더보기
