주요 콘텐츠로 건너뛰기
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20 질문 전체 보기
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 16
댓글 3개
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
댓글 달기
답변 5개
가장 유용한 답변
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
ASUS provide zip file and when we run this command it says missing text files
can you give more detailed information ?
댓글 달기
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Mei tablet bringt das soeben was tun
이 답변이 도움이 되었나요?
점수 0
댓글 달기
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
이 답변이 도움이 되었나요?
점수 0
댓글 달기
forgot screen pattern of phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
linda2222 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 39
전체 시간: 21,131
