주요 콘텐츠로 건너뛰기
Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 질문 전체 보기
질문 마감됨
Ipad 4 Screen Parts Solutions
Hi. I'm looking for solution and parts to fix the broken Ipad 4 screen and a rectangular color issue on the display (pictured below). Should the "iPad 4 Front Panel Digitizer Assembly" fix this or is the problem deeper than that?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I thought I already answered this - but anyways, many thanks for your help!
댓글 달기
답변 1개
선택된 답변
It seems your LCD is broken . That's what this "square" issue is. The LCD lies underneath the glass that serves as touch screen.
Here's the guide for replacing the LCD. It also has links to the needed parts and tools.
Since th e outer glass is also broken, you will ALSO need the "front panel digitizer assembly."
You can buy only the digitizer assembly. Use the guide to remove the broken digitizer. When you get to the LCD, disconnect then reseat the cable of the LCD (gently, those have very fragile connectors). If reseating doesn't solve the "square" issue like you call it (I doubt it will), then order and replace the LCD before re-sealing the iPad.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 336
