주요 콘텐츠로 건너뛰기
현재 iPod Touch 라인은 6세대까지 출시되었습니다.
2619 질문 전체 보기
iPod touch will not unlock
My I pod will not let you slide the bar to unlock. Turns on/off but cannot slide???
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 달기
답변 8개
선택된 답변
does everything work except the slide to unlock?
i mean - that area where the "slide to unlock" shows up - does it work at all ?
most likely the connection is the problem or the digitizer is faulty and needs to be replaced.
since you didn't wrote what ipod touch model you have, i can't provide you the link to the guides for that model.
first try to reset the ipod - press and hold the home and the sleep button until the ipod restarts - try if it works, if not - disassemble it -> select the model and the guide from the menu on the right,
disassemble the ipod and reseat the digitizer connector - if that won't work - the digitizer is faulty and needs to be replaced
해당 답변은 도움이 되었습니까?
점수 4
댓글 4개:
can you tell me what to do plz
I have the newest model iPod it won't let me slide to unlock and if you try to look at your events that napped it won't let you pull down or up and If I hadn't had Siri I would not be able to open or access my apps what do I do??????
I fix mine!The unlock slider does not work after replacing the digitizer on my I pod because I connect the two tape connectors of the digitizer upside down ! Disconnect the digitizer and reconnect the two plugs so you can see the white lines on top of the plugs.I also tried everiting else before I discover myself my mistake.
Can anyone send some instructions on how to do that?
댓글 달기
whatever u read is ok but all u gotta do is hold the button in not the power button till u go to voice control them say face time and it will shoot you to face time then just go back till your at ur home page
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i tried that and it didnt work
댓글 달기
Have you tried cleaning hard your touchscreen ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
SOZ don't know
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi I have the same problem just restart your device and if that does not work plug it into the computer you get your music from thanks for reading and I hope it works if it doesn't work just tell me I have a couple other things but that's back up sorry that u have to do this but it should work sorry for the inconvenience of your device
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
got the same problem and i factory restored it with computer and the slide worked once got in and everything was working so i thought i fixed it then i decided to lock it well it went back to you cant do anything on the screen such as cant get camera, cant slide, cant even slide up the volume, nothing works but after you somehow get pass the screen it works perfectly. like WHAAAT. so it cant be the digitizer. i done some research and it said that under ios 7 doesnt work with slide so apparently you have to update ios to 7 or above! but how? you cant get in phone? dont wanna pay! it sucks, sorry i cant help ill let you know if i get in mine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Read my comment posted by "gheorghe".I fix mine !in November 2015 about unlock switch does not slide after replacing digitizer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yeah I have a really old one and it won’t work. My problem is that I can’t restart it because the off button doesn’t work. That’s why I had to get a new one because I used to just wait until the inactivity timer went and turned it off. Anyways, can anyone tell me how to set to factory settings with a computer??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
scrapmom62 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 32,073
