My power button is stuck and is at a slight angle.
Do I need to open the unit for adjustment, cleaning, or something else?
좋은 질문 입니까?
좋은 질문 입니까?
It's probably getting caught on the rim of the hole it's inserted into. See if you can gently move it away from the side it's caught under.
해당 답변은 도움이 되었습니까?
all the buttons seem to be "off center" as well. Guess I get to open this thing up now.. Thank You!!!
I am having a similar issue...my power button seems to be stuck. It won't click. It's not crooked. I've replaced the power supply. That didn't help. Can you please suggest something I can try to fix this? I bought a new button, should I go ahead and replace it? Or is it something simpler maybe? Thanks in anticipation of your answer. Kirstie :)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 156
